Why not build A resistor Load Bank instead of the motor for the load you could use Switches or Relays to cut more or less Resistance in the load and Monitor the Alternator output with Meters Amps, Volts, and Power (might be Expensive for power meter) would also do double Duty in Winter to help heat the workshop
Doug.
