RCU Forums - View Single Post - Replacing a 46 ax with 4 stroke
Old 08-24-2009 | 10:40 AM
jester_s1
Moderator
Default RE: Replacing a 46 ax with 4 stroke
If your tank is going to be substantially higher than your carburator, a Cline regulator will keep your engine from flooding. It's a demand regulator, which simply means that pressure from the tank can't push fuel into your engine, but your engine can pull as much fuel as it wants out. As long as you have some positive pressure on the tank side of the line to keep fuel going to the regulator, then you can put the tank anywhere you want.
