RCU Forums - View Single Post - Li- Poly
Thread: Li- Poly
Old 08-04-2003 | 05:33 AM
  #43
robhoneycutt
Default Li- Poly
Tailheavy,
yes, that is too much for that motor!!
You will have to replace the field in it or demag it one..
I tried a 3S2P w/ same motor and it is on it way back from the repair shop now!
You need a "L" can and a 18 wind for the 11" prop, or you can amp down to the 2S and maybe use that motor.. Be sure to check the amps, though..
Rob
