RCU Forums - View Single Post - Replacing Nylon pushrod with metal.
Old 08-25-2009 | 12:44 PM
OkadaKeisuke's Avatar
OkadaKeisuke
Default Replacing Nylon pushrod with metal.
Hey all,
I was wondering if it was OK that I replaced the nylon pushrod from my rudder servo to my nose gear with a metal pushrod? I had read some things about metal pushrods possibly causing Rx interference, and didn't know if using a metal pushrod for the nose gear would cause such interference. All I know is that the metal pushrod will not kink at the servo horn like the nylon pushrod did, and if using metal will be OK than I would rather use metal.
Noah
