RCU Forums - View Single Post - OS 46FX Midrange Lag
Old 08-25-2009 | 07:55 PM
spaceworm
Default RE: OS 46FX Midrange Lag
I guess you are running muffler pressure to your tank, but maybe try putting the baffle back in the muffler to see if that helps. Maybe you are not getting enough muffler pressure without the baffle. How far back from the engine is the tank? Seems the problem is only when the plane is vertical for awhile, could be fuel feed problem. JMHO
