RCU Forums - View Single Post - Replacing Nylon pushrod with metal.
Old 08-25-2009 | 10:50 PM
OkadaKeisuke's Avatar
OkadaKeisuke
Default RE: Replacing Nylon pushrod with metal.
ORIGINAL: bruce88123
The correct term is ''wheel barrowing''. http://en.wikipedia.org/wiki/Wheel-barrowing
Heh heh... True enough! But you know, my grandfather made a Wheel Barrow out of a metal barrel the he lopped in half. He would use it to spring clean the lawn. Ironic!
And about changing the strut length, I overlooked that shortening the strut and adding a larger wheel only brings the nose back to its original position (DUH!), as long as I only shorten the strut the difference in distance from the center of both wheels to the outer edges.
