FB-
Way to go......it's a pretty paint scheme isn't it?
Certainly is and it has good contrast between top and bottom. The more paint I get on it, the better I like the trim scheme.
About the wing, (sheet 3, I think), there was another duplicate but reversed, (ie backward) sheet included, so both sides of the wing could be built at the same time. There is a note on the plan that tells you to cut and join the plan on "this line."
To build both panels of the wing at the same time, one would need a pretty large building board.
FB
