RCU Forums - View Single Post - got the kit
Thread: got the kit
Old 08-26-2009 | 02:05 PM
Missileman's Avatar
Missileman
Default RE: got the kit
Servos won't make a huge difference balancing unless they are mounted in the tail as some are.
The battery is the heaviest item that can be moved around.
I will balance a plane with the battery out and lay it on the plane in various locations to see where it needs to go.
You can even add a hatch to access a custom made battery compartment.
Balance with the tank empty.
