RCU Forums - View Single Post - Brushed Motor that can handle 3S Lipo?
Old 08-26-2009 | 05:49 PM
rebuilder's Avatar
rebuilder
Default RE: Brushed Motor that can handle 3S Lipo?
ORIGINAL: mazdaprotege4
I have a Novak Tepmest Max which can handle a 10-cell pack (so 12 volts total) so I am thinking of hooking up a 3S lipo (well within the limits of the ESC) but I am wondering if the motor (Speed Gems 17T) will be able to hold up to the increase in votage? Has anyone found a motor that can handle 11.1V with no problems? Thanks
Yes, with absolute certainty, this can handle 3s...............specs are:
Nominal voltage 12 V
Operating voltage range 4,8 ... 14,4 V
No-load rpm 17200 min–1
No-load current drain 1 A
Current drain at max. efficiency 7 A
Current drain when stalled 40 A
Max. efficiency without gearbox 77 %
Length of case, excl. shaft 57 mm
Diameter 37 mm
Free shaft length 8,7 mm
Shaft diameter 3,17 mm
Weight 220 g
http://www.hobby-lobby.com/speed_600...QueryId=162847
next time i guess i'll just answer the original question exactly as it is asked.
