More Pull Pull help.
Guys,
I'm getting ready to set up the pull pull rudder on my DP Edge. This is my first pull pull set up.
With the dual elevator servos, it is going to be a little tight, but it will work.
What is the best way to find the exit locations for the cables?
Should I cross the cables or not?
What do you guys do where the cable exits the fuse? Do you just leave it as is, IF the cables run through plywood? How about if the cables are going to end up exiting through covering material ONLY?
This is a nice 1/4 scale DP Edge, and I want to do this RIGHT!
Thanks for any help fellas.
