RE: OS 55AX break-in issues
Have you tried to open the throttle full open with the glow driver still connected? This would help keep it running if it were to rich. My guess is that your running a little lean and the engine will die even with the glow driver connected. If it does die then open the needle at least another half to full turn. The recommendation settings are a ball park type setting assuming that your fuel supply is good.
