RCU Forums - View Single Post - Project poulan
Old 08-28-2009 | 11:49 AM
  #39
Ralphbf's Avatar
Ralphbf
My Feedback: (27)
Default RE: Project poulan
The best results usually come from:
Bowman Ring
Exhaust timing 150 degrees.
Matching the transfer ports between the case and the cylinder.
Opening up the stock muffler. In your case I'd braze a 3/4" tube in place of the existing out let.
A Carb. with 2 mixture screws. 3 or 4 MM bigger at the most. A smaller Carb. will cost you a few RPM but will transition better
Transfer ports are usually pretty good. You might try to square them up, I don't suggest raising them.
Remember more is not always better.
