RCU Forums - View Single Post - CGRCJets A-10 Build Thread
Old 08-28-2009 | 12:00 PM
  #50
Ron101's Avatar
Ron101
My Feedback: (22)
Default RE: CGRCJets A-10 Build Thread
Doc,
If you are going to run the Dyn-E-Max.... get the 4035-630KV scorpion...
To save weight and money on 10s.. I'd bet you could get by with just the CC85HV
on 12s this setup pulls about 95 amps... so I'd guess on 10s you'd be around 80 amps.... the 110hv wouldn't hurt..just more money and weight
As for the packs.... you need 30c packs at least...don't run 25c packs
The Xtreme Power Systems packs are very good and cheap (30c) the Hyperion G3's 35C are great also.. of course the thunder power 30c are great but cost alot and are no better than the others
the flightmax zippy 30c packs direct from china are also great and dirt cheap...
Also take a look at the Stu Max fan... I'm running one in my Comp ARF Spark and it's the most amazing fan I've ever owned and I've had a few... it's sounds so sweet
very much like a turbine
I'd go with what was said before run 6s 30c+ 5000 mah - 4s 30c+ 5000mah x 2
Link to Dyn-e-Max- http://www.dyn-e-max.com/index.html
Link to Stu Max- http://www.stumaxaircraft.com/pages/SM110.htm?t=739147
XPS Packs- http://www.xtremepowersystems.net/products.php?cat=16
Hyperion G3 35c packs - http://www.allerc.com/index.php?cPath=3_4_93
Hobby City Flight Max Zippy 30c - http://www.hobbycity.com/hobbycity/s...5&v=&sortlist=
my friend is running 12s of the 30c turnigys from hobby city and says they are working very well also
(he is pulling about 90 amps on a very large 12s heil 90 sized)
hope that helps
Ron
