RE: ... electric help...
Ummm, not real sure what you mean by wirelessly. Use of something like an Astro meter or Watt meter, plugs inline between the pack and esc and reads out volts/amps/watts. Gives you real time readings.
And there are some units available that allow you to download the info to your computer after a flight, aka like a flight recorder.
That way you see how your system is performing over an extended period of time.
