RCU Forums - View Single Post - MVVS Twins
Thread: MVVS Twins
Old 08-28-2009 | 09:33 PM
fujiman
My Feedback: (133)
Default RE: MVVS Twins
mrbob, did some research and found header pipes for a fox,os.60, enya x .60 macs #2850 fit perfectly. the fox tilt up/tilt down (right and left bank) will work for the mufflers. now all I have to sort out is the running problems with this thing. I think the main problem with running probs. is in the reed set up. one fellow here in the forum said he fabed up a different reed set up drilled out the reed boss or flange to match carb base size. wonder what he used for the "new" 4 reed sys. not much room in the reed throt casting in eng block. I'll be lowering the compression also with a couple of extra head shims. maybe a wt-499 alky carb that some guys are using on supertigres.
