ORIGINAL: freeair
make sure your prop is perfectly balanced. this will stop alot of bad vibes.
Yep it's balanced using my magnetic balancer. I sanded the back of the heavy blade as even as possible until it balanced perfect.
I still have some airframe vibration at idle. What method do you use to balance?
