RCU Forums - View Single Post - Compression ratio mods?
Old 08-29-2009 | 09:39 AM
tkg
Default RE: Compression ratio mods?
Just cut the cylinder untill the squish is tight as you want it. Thinning the top of a piston may not be good for engine life.
Maybe just measure the base gasket , leave it out and cut the ports to match. Then see what happend.
