RE: All things TXT-1
I've got it screwed down tight, the cap, that is and that whole assembly keeps coming apart, but I've since glued it, now it's staying put but it's coming off the metal spline on the servo. I think it's stripping or slipping down, Thinking about just gluing that one for now too. Haven't had any problem with the front servo, but that's the one that seems to have more power. When I manually move the wheels back and forth I can tell a difference between the front and back wheels. The front has a lot more resistance even with it not slipping off the spline.
Yeah, just using the stock controller for now. I'm probably going to have to upgrade to a better one.
As far as the stock motors, you can only run one battery to it? What's the max voltage? 8.4? on a 7 cell? I don't want to experiment here if you know what I mean. Mostly just looking for longer run time and maybe a little more torque. Right now I only have a 1500 nicd.
