RCU Forums - View Single Post - It's here and Looks GOOD new Hangar 9 Taylorcraft
Old 08-29-2009 | 06:45 PM
Zippi's Avatar
Zippi
My Feedback: (10)
Default RE: It's here and Looks GOOD new Hangar 9 Taylorcraft
ORIGINAL: dale691
And some more. I haven't had much to do with the Zenoah, are the mountings different on the 20 and the 26. The only marks on the fire wall say 20ei.
dale691,
The pics look good. Can't wait to get mine. What you can do is remove the flat mount plate from the back of the engine and mark a center line from left to right. Draw a horizonal line thru the marks for the G20 on the firewall. Lay the mount plate on the firewall and line up your center line on the mount plate with the center line on the firewall and the horizonal line you marked on the firewall. The horizonal line should be lined up in the center of the mounting holes. Now, use your mount plate as a template and mark the hole locations and drill.
