RE: AquaCraft Alligator RTR
carb is not something that normally that needs to be check, you are correct, if the carb is loose, it would run like crap. In most cases this something that will happen all at once. Really the only screws that I check are the mounting screws, I myself do not go over ever screw on the boat, but do recommend doing so.
