RE: Question about gas to oil mixture........
Changing the oil ratio will probably not do anything for the transition issue. It is more than likely a tuning problem. Maybe a mis-adjusted carb, problem inside the carb, wrong carb for the engine or maybe even a spark plug/igniton problem. I'd bet on a carburetion issue personally.
