ORIGINAL: Avaiojet
OK,
I can understand the 5 to 10 degrees. Is the thrust tube set at the same degrees as the turbine?
Or is the turbine and thrust tube set at the same angle?
Charles
Hey Charles,
As far as I know the tailpipe and turbine must always be in line. The exhaust gas must be directed down the center of the pipe.
