RE: Thrust angle and wing incidence/angle of attack?
Yes as mentioned the pipe should always be aligned with the turbine, so both things should be set looking downward at the same angle. About the turbine it is not critical at all, as it is always installed near the cg. Installing the batteries, uat,etc.. somewhere between it and the nose will probably balance the plane in the case of the C101 without any lead.
