RCU Forums - View Single Post - MVVS 26 Sagging
Old 08-31-2009 | 01:26 PM
pe reivers
Default RE: MVVS 26 Sagging
The problem you encounter now, is that the fuselage inside pressure is by no means constant, and changes when you apply rudder (Yaw the plane)
Connect the static line to a static tube ( http://prme.nl/forum/viewtopic.php?t=205 ), and your problem should be solved.
