RE: Echo 50cc Short Block Conversion - Seeking Advice
Can any of you guys give me the dimensions of the BME 50? I need to know the length from front of the prop hub to furthest point in rear of engine, and also the maximum width of the engine from outside of carb to outside of either a stock muffler &/or a Pitts muffler. I'm trying to find an engine that will fit under the cowl of an old ARF/ARC called a G-Shark. There is not a lot of room under itscowl; about 6.25 inches from firewall to front of cowl, and about 5.75 inches across.
Thanks.
