RCU Forums - View Single Post - Shear Webbing
Old 08-31-2009 | 03:33 PM
HighPlains
Default RE: Shear Webbing
What happens is that the upper spar is put in tension while the lower spar is put in compression, the resulting forces between the upper and lower spars is a shear force at a 45 degree angle to the spars where the upper spar is trying to elongate while the lower spar goes into compression (assuming a positive G load).
Are you sure about this? I would assume that with positive G load, the upper spar would be in compression. What am I missing?
