ORIGINAL: Redvanmafia
I'd like one of these buggys, but im under the impression there only good for packed dirt and on road, and nothing else because of there low GC small tires and such, but with brushless they must be some kind of fast!
I don't understand why you would be under the impression that the DB01 would only be good for packed dirt or on road as you say. As far as small tires go, if you're not aware tires are interchangeable. What did you mean by low GC? Were you referring to CG, low center of gravity? That also can be fixed as well. This is done by an old method, which i believe is an ancient Chinese secret called ride height adjustment. If your question was meant to ask whether or not the buggy is race worthy, the answer is YES.
