RE: Receiver swap
Either solution would work, you might want to get some help from someone on soldering. You will need to solder a lot of times. Check with someone in your club for help. Or just remove the tab on the Futaba servos. That is what the new? universal plug is, whatever you want to call it. Just make sure it is plugged in correctly.
Good luck
