Originally posted by Geistware
From the drawing supplied, it looks like the gear is mounted to the wing. While building and installing the mounting plate for the wing, you need to re-enforce the mounting plate in the wing to keep it from ripping out. I designed a brace for mine that worked for over 100 flights.
Yep it look like, but if you look again it is mounted on bottom of a fuselage.
