RCU Forums - View Single Post - Nitroplanes.com 2009 SD Model 3 Channel Condor EPP Foam Pusher Remote Controlled Bobcat Jet
Old 09-01-2009 | 11:00 AM
opjose's Avatar
opjose
Default RE: Nitroplanes.com 2009 SD Model 3 Channel Condor EPP Foam Pusher Remote Controlled Bobcat Jet
15 degrees is excessive, and likely to cause problems.
You only want 2-4 degrees of positive AOA at most.
Bending the rear gear back is not a good idea, as it makes the plane more difficult to rotate.
You need to decrease the length of the rear gear a bit by cutting and bending.
