ORIGINAL: FalconWings
NuB Questions:
1.Can't seem to be able to mix down elevator to brake (JR 9303 2.4), could it eb EPA related?
2.What is the extension with the amplifier for?
3.What is the set of extra small screws with gasket for?
4.Is there a way of retaining system pressure when I turn off the Rx?
Thanks!
David
David....
1. little tough to answer this one, not sure what your programming issue is from your question? Are you getting brake actuation but not full brake?
2. Not need, can be discarded.
3. spare screws for the add on ports on the side of the valve.
4. No, all of the electronic valves bleed off the pressure to the gear/doors when powered down. This is normal operation.
Matt,
I suggest you call to discuss....
Todd
