RE: Note: Shadel/Nelson YS Piston & Liner Installation..
Hi Chuck,
WOW, I can't believe that got past Henry...[:-]
How did you 'trim' the piston? Machine it or dremel it? Nice work!!
On another note... ever have problems popping the con rod off the crank pin? I have a Hanno (with the liner out of course) that I can't seem to get the rod off the crank-pin (the other 3 I just disassembled - the popped off easily). I'm thinking the rod isn't sliding back on the piston pin; so maybe I'll try some penetrating oil. Any thoughts??
Regards,
Will
