RCU Forums - View Single Post - NEW THREAD NAME: Let's Fix Bluey
Old 07-01-2003 | 05:01 PM
Cactus.'s Avatar
Cactus.
Default NEW THREAD NAME: Let's Fix Bluey
umm info over load right now
i was surprised to see the rear stay connected to the sail to tension it.
your pic dosnt show because its a .bmp btw
i was thinking of making a new head, i have enough CF scraps here to make a head, and new bits at the bottom of the sails.
will check the price of CF tube when i get a chance to goto the LSH.
green spiderwire... where can i find this? fishing shops? i was gonna use the stuff i have on the 575, black and white braded strand.
im gonna have a good look at these pics and then reply again.
oh yes, The pink line will come from atop the mast, down (connected) to the sail and PAST the end of the sail to atatch to the very tippy front of the boat.
i think the pink already does this.. ah, its attached to the sail, then looped round the ali bit at the bottom, not to the front of the boat.. so if i do this i can loose the green yes? isnt the bow to far away then? and the line trying to pull the sail forwards. currently the rear attachment is to the servo i guess.
if i get your BMP pic right, i attach the rear of the rear sail to the boat, then the winch adjusts the front? this is backwards to what i know.
ah man, im just gonna have to go back and check the pics again lol
im used to the 575. 4 lines tension the mast. then one tensions the jib and gos to a side mount, the other tensions the mail sail and goes to the other side mount.
jib currently has no fixings, its not big, so i'll sew on hooks and have another wire like the rear.
anyway, time to check these pics again
BIG Thanks
keep it comming.
heres a simple pic of Bluey if anything needs drawing.
