I am guessing this is how your radio set up is? If not, I higly recomend doing so.
Also, you can usally get SpiderWire at your "Local Shop Hobby"
Other wise, every big fishing store has it.
The two servos are mounted on two sruce rails that run across the boat and are epoxied in place. The sail servo arm should be as long as possibal to maximize sail travle.
Oh yeah, have you found the keel yet? After all, its a very important piece. You wouldent want it to cap size it and drown would you? :drowning:
