RCU Forums - View Single Post - CGRCJets A-10 Build Thread
Old 09-02-2009 | 10:13 PM
  #108
cgrcjet's Avatar
cgrcjet
Default RE: CGRCJets A-10 Build Thread
Here are the slats , stand offs and the strakes that goes on the end of the slat on the inner wing portion of the A10. The slats have an old mount setup that i did not like so these can be ground off and you can cut a slot for the standoffs in there place. You will also need to cut some small slots in the wing for these. The standoffs have tabs on both sides for joining the pieces together. In the picture i have marked the larger tab which goes into the slot that you cut into the slat. The smaller tabs goes into the wing. The strake will sit on this flat part of the leading edge and up against where the wing starts to look like a actual wing leading edge. CA the strake to the wing and slat. With the standoffs and strakes glued in place it locks it all in.
Oh and the slats will need to be lined up and trimmed flush (belt sanded is easiest) with wing root before gluing all this in place.
chris
ID:	1267789   Click image for larger version
ID:	1267790   Click image for larger version
ID:	1267791   Click image for larger version
ID:	1267792   Click image for larger version
ID:	1267793   Click image for larger version
ID:	1267794   Click image for larger version
