RE: Rectangular Tapered wing combination
The tapered sections will only be as strong as the joint to the last balsa rib unless you imbed the ends of the spar or otherwise incorporate the foam sections into the wing. I don't thing the end cemented and skin of covering alone is enough to support much of a wing panel. Were you planning om having a balsa skin over the foam? That would help some. As would carbon fiber rods or stiffeners.
