RCU Forums - View Single Post - Source for lead weight
Old 09-04-2009 | 11:29 AM
Rodney
Default RE: Source for lead weight
I also find that using lead shot and epoxy works best and is easiest to use. There is no heat involved and it is easy to fit into odd shaped areas. If necessary, you can even make balsa molds or partitions to contain the mixture anywhere you want it using scrap balsa. On the cheap, if no great amount of weight is required, even sand or small rocks and epoxy works well.
