RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 09-04-2009 | 06:00 PM
  #12216
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
Joey,
Pictures are worth a zillion words. The tail blade on the left, the trailing edge should point skyward. Put you finger in the notch and turn int counter clockwise. The main blades should spin clockwise, viewing the heli from the top. If that's all good, you may try to increase the setting in the TX for the gyro, by 2 percent, try it out. Continue to bump the setting 2 percent, until the spinnig goes away.
Also, you may have the tail servo move on ya. Check the tail sevo for centering. Disconnect the gyro and plug the servo into channel 4 of the RX, make sure the sevo is centering properly and that the tail slider is centered on the tail shaft. Disconnect servo from RX and re-install the gyro leads. (Channel 5 is for the signal lead from the gyro, it's the plug with one wire.)
Dave / Choppersrule
ID:	1268675   Click image for larger version
