ORIGINAL: GreenAcre
Might be your expo? What is your steering expo set at? I use -75 for my low rates. And -4 to -45 for high. (high rate is used when I turn around on the runway) Then I switch to low rates. The steering should barely move when taking off! What radio are you using? The expo is I believe, switched on JR and Futaba. I use Futaba and to get LESS sensitivity, I use - On JR I believe its + for less sensitivity. Hope that helps.
Mario
Mario-
I'm using a JR 9303 radio. I have the steering servo mixed with the rudder channel. Rudder is set at 100% travel +30% Expo on High Rates and 70% travel at 30% Expo on Low.
The Mix 1 program for Aux 4 (steering) is:
Point-0 -100
Point-1 INH
Point-2 INH
Point-3 INH
Point-4 INH
Point-5 INH
Point-6 +100
Steering cables are attached to the steering servo horn at the second hole from the inner-most hole.
Mike
