RCU Forums - View Single Post - Snaprolls = bubbles?
Old 09-05-2009 | 09:38 AM
highhorse's Avatar
highhorse
Default Snaprolls = bubbles?
Did a series of snaps the other day and the fire went out approx 15 secs later with a tell-tale vapor trail. No other issues in the 4 previous flights or the one subsequent. "Fuel Fail" was the indication on the P-60's data terminal.
The BVM UAT had little/no air in it when examined on the ground, NO bubbles visible in any lines elsewhere. Two tanks in series, large felt clunks in each, aft tank 25% and fwd tank 100% full.
Examining the evidence, I'm nearly certain I ate a bubble as a result of the snaps, which were a first for this model. Perhaps I simply dislodged a "fuel fart" from the JetCat filter, which is mounted loosely and vertically? I will try to replicate the failure in the coming days (with a bunch of altitude), but I would be grateful for your collective input in the meantime.
Thanks all, D.
