RCU Forums - View Single Post - manually control speed
Old 09-05-2009 | 09:26 PM
The Ghost's Avatar
The Ghost
Default RE: manually control speed
You need to get your self a watt meter or simmilar. I use a meter from Turnigy and it measures Amp draw, Voltage, Mah used as well as live time watts, so you can see straight away if the changes are better.
Or for a couple of dollars you can buy just a servo driver.
Cheers
ID:	1269238   Click image for larger version
