RCU Forums - View Single Post - Sail Setup
Thread: Sail Setup
Old 09-06-2009 | 01:06 PM
mfr02
Default RE: Sail Setup
It only needs an independent control if you really want one. There will be an adjustment to set the size of the slot between the leech of the jib and the mast, but this really doesn't need adjusting once the boat is sailing. A properly set up yacht will always go fastest when the driver stops slowing it down. The more things that can be adjusted by remote control, the better the chance of a bigger, better muck-up.
