RE: Official DB-01 Durga Thread
Hmm in regards to the rear upper arms rubbing the inside of the rear rims with TRF dampers, I have the stock tower set up with TRF dampers but theres about 1.5-2mm clearance when my arms are fully extended down.
Shock mounting holes i'm using, Top 2nd one in from the most outer one, and Furthest outter hole for the arm.
It seems to be fine, but maybe because i'm not using Stock Rims? DF03 rims with 12mm hex conversion.
