RCU Forums - View Single Post - EDF55 HELP!!!!
Old 09-07-2009 | 10:43 AM
FlooredCOBRA
Default RE: EDF55 HELP!!!!
Wow you posted that a few days ago and still no help. I can try to take a stab at it. So your motor shaft does not have the flat spot cut on it correct? The part to where the set screw screws to when tightened? If that is all it is I would cut a flat spot with my dremel tool. Maybe that will work out for you. Good luck!
