RCU Forums - View Single Post - Storing A-Jet?
Old 09-07-2009 | 09:47 PM
KC36330
Default RE: Storing A-Jet?
if it's a JetCat unplug the battery from the ECU. if you don't the battery will slowly drain and when it reaches a certain point of discharge the ECU will default and the next time you power on the turbine it can think it's some different turbine (had a Titan SE think it was a non SE 120)
