ORIGINAL: KC36330
if it's a JetCat unplug the battery from the ECU. if you don't the battery will slowly drain and when it reaches a certain point of discharge the ECU will default and the next time you power on the turbine it can think it's some different turbine (had a Titan SE think it was a non SE 120)
Thanks KC, Does this hold true to Jet Centrals as well?
