RCU Forums - View Single Post - Hangar 9 Twist 3D Part II - Thread Continuation
Old 09-07-2009 | 11:48 PM
  #3954
martin3737's Avatar
martin3737
Default RE: Hangar 9 Twist 3D Part II - Thread Continuation
ORIGINAL: martin3737
Prop Recommendation
Hey Guys,
What are you using to hover a Saito .72 (15% nitro) on your T-T? I've been running an APC 13X6 but that's fast and sport plane. Seems like ground clearance prevents me going longer that 13''. But also, the prices go up a lot at 14''. So, I was thinking about 13X4 and perhaps I may need to EPA down the throttle. I'm guessing that the RPM's will be real high. Any thoughts?
Thanks!
P.S. I tried 20% nitro (Powermaster) but the cost/benefit wasn't good.
Well, It's true; at full throttle the engine winds too fast, maybe 11500rpm. I don't EPA-down the throttle, just don't go full too much. I wonder how different the 13X4"W" (wide) is from the 13X4 I'm using...
