RCU Forums - View Single Post - Heat gun doing more harm than good. Need help/suggestions.
Old 09-08-2009 | 11:22 AM
vmsguy
Default Heat gun doing more harm than good. Need help/suggestions.
I've been covering my latest build.. (Senior Telemaster)
And I ran into an problem trying to shrink the MonoKote down...
One of the areas I'm trying to shrink is long and narrow, and I need the shrinking to happen along the shorter axis...
It seems like the heat gun is doing more harm than good. I can get the monokote heated up, but the wind from the gun stretches it out so much, that it actually stretches the coating out... By the time it cools down/shrinks down, it doesn't shrink enough.
Plus... An adjacent area needs shrinking, and I can get that one shrunk down.. but then return to the problem area.. the overblow screws up the first.. Argh!!!
So.. Is there a heat gun out there that delivers the heat, but not all the wind volume????
I tried pulling the gun further away from the surface, putting it at an angle..
As I type this.. I'm thinking of using a second iron, set on higher (shrinking temp) temperature, move it over the area...
Thoughts???? Ideas?????
TIA
