RCU Forums - View Single Post - Heat gun doing more harm than good. Need help/suggestions.
Old 09-08-2009 | 12:24 PM
Don41's Avatar
Don41
Default RE: Heat gun doing more harm than good. Need help/suggestions.
ORIGINAL: vmsguy
I've been covering my latest build.. (Senior Telemaster)
And I ran into an problem trying to shrink the MonoKote down...
One of the areas I'm trying to shrink is long and narrow, and I need the shrinking to happen along the shorter axis...
It seems like the heat gun is doing more harm than good. I can get the monokote heated up, but the wind from the gun stretches it out so much, that it actually stretches the coating out... By the time it cools down/shrinks down, it doesn't shrink enough.
Plus... An adjacent area needs shrinking, and I can get that one shrunk down.. but then return to the problem area.. the overblow screws up the first.. Argh!!!
So.. Is there a heat gun out there that delivers the heat, but not all the wind volume????
I tried pulling the gun further away from the surface, putting it at an angle..
As I type this.. I'm thinking of using a second iron, set on higher (shrinking temp) temperature, move it over the area...
Thoughts???? Ideas?????
TIA
Put away the heat gun and use your iron. Heat guns (IMHO) are only useful for heating your shop and blowing holes in Monokote. Even the tip of a soldering iron (not touching the film) can be used to deliver heat to a difficult area.
Regards
