ORIGINAL: andrew76
thanks for all the info i also like the matis is deferent every one at the track has the 8t and i just don't want to be one more the oney thing i don't like is the stiring but that can be fix and the low neddle comes off
Did you say low speed needle comes off? If it is the needled that is on the side of the carb and NOT on the SLIDE of the carb that opens and closes then that is the midrange needle if you are still running the axial .28 it comes with. What you need to do is take it out but make sure the setting that is is at (usually flush) and put some shoe goo on the threads and put it back in. That will help hold it in. If that falls out and you lose it you are going to be one mad person! lol
